Trim tab length on Prince mono (DF 26)
  • BILL OXIDEAN
    • Sep 2008
    • 1494
    Hey guys,
    I used to have a "Prince" mono that ran great, I've built up this carbon Delta Force knockoff from WV design out of Sweden
    I'm using some stainless JoysWay tabs that I really like, but my Prince was very fast and loose. Can any of you tell me the length of the stock trim tab from transom to tip?
    I'm gonna' cut a set of JoySway tabs down to match.
    Thanks! I'd order a set, but I like the ones on here.
    BTW, this is how my CF edition came out
    i fabbed most of the bracketry myself. A rare deep view into one of my boats..
    10150759_10152328695237148_1647584734_n.jpg1964816_10152326426562148_1906550850_n.jpg10156174_10152326235337148_1042765282_n-3.jpg10154338_10152328305707148_547639178_n-2.jpg970985_10152328305037148_1932038016_n.jpg
  • martin
    • 2869
    Bill the tabs on the knock off boats are 31.5mm or 1.25" from transom to tip, what type of shaft are you using in this boat. Regards Martin.
    • Darin Jordan
      • 8332
      Originally posted by martin View Post
      ... what type of shaft are you using in this boat. Regards Martin.
      The answers to "all" your questions... :)
      http://forums.offshoreelectrics.com/...285#post559285
      Darin E. Jordan - Renton, WA
      • martin
        • 2869
        Thanks Darin ,hadn't got down to the pics section. Martin.
        • Fella1340
          • May 2013
          • 1025
          That boat should run on "bling" alone, forget the batteries!
          • BILL OXIDEAN
            • Sep 2008
            • 1494
            Thanks for the replies guys. Anyone know the stock distance from rudder blade tip to transom? : )
            • martin
              • 2869
              Transom to front edge of rudder is 40mm.
              • Norwest
                • Mar 2014
                • 165
                • martin
                  • 2869
                  The stock Prince/ knock off 26 that I have which came from Kintec & has the same rudder as the HOR version is 40mm from transom to front of rudder blade.
                  • BILL OXIDEAN
                    • Sep 2008
                    • 1494
                    Thank you Martin!!
