Complete NEWB with question on battery palcement and prop selectio
  • beancounter
    • 4
    Hi, I am a complete NEWB to boats, I recently traded a quad copter for an Insane 34' Mono. I have two questions that I need advice on with the setup. This boat for my son who has out grown his mini-mono even with the hop ups we did. He has mastered that boat but is only 11 so I am looking for recommendations more towards longevity of the electronics and driving stability rather than all out speed. The previous owner also a boat newb ran it on 6s and said it ran good, I will run it on 6s as well because I have the batteries already. It has a Leopard 1400KV motor and a 180amp hobbywing esc. I want to get an additional prop but don't have a clue to the size that is on there, can anyone suggest a good all round prop with $$ in mind again not looking for all out speed here.
    Second question is as far as battery placement goes, do boats have a balance point like we have on airplanes? I bought some battery mounts from OSE and before I glue them in place I want to know where they should go for the boat to be nice and stable. I have attached some pictures as well. Thanks.
  • martin
    • 2869
    Re cg on a mono, a good starting point is 30% of the hulls length forward from the transom ie on a 34" hull it would be 10.2". Re props you need to give the motor size ie diameter of the motor ( the actual motor can size ) & length.
      • 7990
      The motor looks to be either 36mm or 40mm in diameter. An m440 prop or CNC 4014 should give decent speeds with reliability. What packs will you use? Boats draw a lot more amps than cars or planes do an need better packs.
      • beancounter
        • 4
        Motor specs
        Leopard 4074 Motor.
        40mm Diameter by 74mm Long
        http://www.offshoreelectrics.com/pro...?prod=leo-4074
        • beancounter
          • 4
          I have 2 3 cell 5000mah 40C batteries and 2 6 cell 3300mah 30c but we mainly use the 3s as the 6s are for my planes and don't want to eat them up in the boat.
          • beancounter
            • 4
            Thanks guys forthehelp thus far.
