I really like the price of the carbon props in the OSE store. I'm really hoping to upgrade to the 40x57/3 from AQ/GR but was hoping to find an equivalent in a 3 blade carbon prop. I see some that are 40mm, but they are 2 blade. The 3 blades go from 39 and then jump to 42 mm. Any suggestions?
GR 40x57/3 Graupner Equivalent
Tags: None
The GR 40x57/3 is a lifter prop, correct nomenclature is: L40x57/3 , I don't think any of the carbon 3 blade props are lifter ones.Originally posted by TurbineTester View PostI really like the price of the carbon props in the OSE store. I'm really hoping to upgrade to the 40x57/3 from AQ/GR but was hoping to find an equivalent in a 3 blade carbon prop. I see some that are 40mm, but they are 2 blade. The 3 blades go from 39 and then jump to 42 mm. Any suggestions?
If, on the other hand, what you meant is the GR 40x52/3, then I find the closest "plastic" prop to this one is this:http://www3.towerhobbies.com/cgi-bin...?&I=LXMWB2&P=Z, in fact, I have used this to test on hydros that came with unknown cables which might lose me a good metal prop.
But as you can see, this prop is not cheap considering the fact that it is not metal.Too many boats, not enough time...
Forgot about the lifting designation. I was actually looking for a L40x57/3. Is there a particular one of those carbon props that would give similar performance to the L40x57/3?Originally posted by tlandauer View PostThe GR 40x57/3 is a lifter prop, correct nomenclature is: L40x57/3 , I don't think any of the carbon 3 blade props are lifter ones.
