New Fightercat 240 ESC only 50% power?
    • 5660
    Originally posted by Jlov View Post
    Yes because both batteries run boat fine when connected by themselves. What motor and ESC were you using Tim when that happened? Thx Jeff
    That was a while ago, I usually only run 5.5 bullets, that was an exception, I believe was a Venom P1 Fountain as I wanted to run 3s2p, the ESC was Seaking120A and motor was stock out runner. The point is that it should have worked, but it was zero juice! It ran fine with each individual battery, but hook them together and there was not a sign of life.
    I did ask the question here and I got zero answer. Knowing if I pushed any further it would have landed me in the "ignored" list again , I quit while I was ahead . I ran that boat on 4s since and tried my best to forget the mystery.
    • Jlov
      • Nov 2013
      • 825
      Yea but I just want longer run times so I'm gonna get to the bottom of this.... someone on here will know the answer.
        • 5660
        I am sure you will... Deans plug and Venom P1, Nah, nobody takes them seriously...
          • 7651
          [/B]
          This is very curious, I have been running 2P with just about every kind of ESC and have not run into this. I have a couple of those 240's here as well Jlov. I could test.
          • Rocstar
            Joel Mertz
            • 1509
            Ok I was hooking up two 4s 4000mah lipos in parallel like in the pic. Got nothing but half power. Took those out and ran a single 4s 5300mah Lipo and it ran perfect. Anybody know what that can be? Thx Jeff
            [ATTACH=CONFIG]113338[/ATTACH]
            So where are you at now? Is the controller still just beeping? Or will it run with one pack only? Do you have a meter to check voltage with the batteries in parallel?
            • gsbuickman
              • Jul 2011
              • 1292
              If it were me & I was going to run 4s twins in parallel I'd build them with 5.5mm connectors. Its simple to solder bullets with a butane pencil torch. Deans are only good for 60A.
                • 5660
                He is using 5.5mm bullet connectors with a set of adaptors from Kintec, I built my own and also use Kintec's w/o any issue. I was the one who was relating a similar experience with Deans. Sorry to cause any confusion.
                • gsbuickman
                  • Jul 2011
                  • 1292
                  No biggie bro
                  Connectors are weird sometimes. I've had brand new connectors fail for no apparent reason like a ford pinto or something
                  I've got 2 female deans to m/f 5.5mm bullets I use for charging adapters & on the astroflight ESC in my villain. I got them off fleabay for $3 apeice I think. I think it'll handle a run in the villain x on 5000mah 5s2p alright.....
                  • SloHD
                    Slow Electric Addict!
                    • Apr 2013
                    • 337
                    Put the kintec connectors on one battery and hook it up to the esc, and see what you get. That will tell you if the kintec connectors are cold somewhere.
                      • 5660
                      Great idea, be sure to tape/cover the exposed connector!
                      • Jlov
                        • Nov 2013
                        • 825
                        No Rocstar ESC has stopped the beeping. It's running great on one Lipo. I do have a voltage meter yes.
                        Good idea Slo. I will try that in morning.
                        • Jlov
                          • Nov 2013
                          • 825
                          EOk think I figured it out. These two 4s 4000mah lipos I bought used are the problem. If I run them in parallel or series boat goes slow. I ran them singularly with y connector like Slo suggested and still ran slow. I put a 4s 5300 in it and it ran perfect again. Can not fit both 5300mah packs in it to test the parallel but I'm pretty sure those 4000mah packs are bad. I have a little voltage checker. What should they read after a run and after a charge? I ran them in parallel for about 1 min and in series for about 1 min.So not much run time
                          After the short run they read
                          1-3.91
                          2-3.89
                          3-3.91
                          4-3.89
                          All-15.6
                          1-3.86
                          2-3.83
                          3-3.86
                          4-3.87
                          All-15.4
                          After charge they read
                          1-4.18
                          2-4.17
                          3-4.18
                          4-4.20
                          All-16.7
                          1-4.18
                          2-4.17
                          3-4.18
                          4-4.20
                          All-16.7
                          Are these lipos ok? Each one took twice as long to charge as the bigger 5300mah packs
                            • 7651
                            The voltages all look OK but how about the internal resistance. They really lose their poop if stored in warm places.
                            • Jlov
                              • Nov 2013
                              • 825
                              No I bought them from a very experienced boater. He used them day before I got them from him. He suggested the 25c rating may not be snuff for my set up.
                              • SloHD
                                • Apr 2013
                                • 337
                                Does your charger show Internal resistance?
