Rudder Bushings
  • BAZCNG
    • Dec 2013
    • 61
    Rudder Bushings
    Can someone please help were I can purchase new bushingsIMG_1461.jpg for my rudder post
    • 9438
    Who is the hull manufactured by? What are the dimensions of the bushings?
    • properchopper
      rcgoatbuild@snotmail.com
      • 6958
      Need to know the o.d. of the rudder pivot pin. These work for the FE30 but yours may be different. You can easily drill out your rudder stem 3/16" for these and get a 1/8" shaft and make a new post if all else fails
      http://www.offshoreelectrics.com/pro...od=oct-oc4ltsb
        • 4297
        Looks like a PB Bud,
        But not sure if it is stock hardware.
        • BAZCNG
          • Dec 2013
          • 61
          It is a pro Boat 1/8 miss bud 3/16 inner and 1/4 I will drive the faulty on out and check
          • properchopper
            • 6958
            http://www.offshoreelectrics.com/pro...od=oct-oc6ltsb
            • gsbuickman
              • Jul 2011
              • 1292
              I"d like to find a rudder that I can throw bearings in, just like all the other bushings I replace with bearings :-) ....
              • BAZCNG
                • Dec 2013
                • 61
                IMG_1462.jpg hi this is the bushing knocked out 3/16 internal .318 inch external if anyone has any ideas ?
                • danielplace1962
                  • May 2010
                  • 91
                  Those are Proboat specific. 3/16 I.D. X 5/16" OD. Those are the same as they use in their struts and rudder brackets.
                  Buy the rudder bracket and knock them out.
                  • BAZCNG
                    • Dec 2013
                    • 61
                    Done thanks for your help
                    • BAZCNG
                      • Dec 2013
                      • 61
                      Hi all I found another place that has all Bushings
