ok putting a new motor in pursuit wanted to know if thrust bearing needed beings they don't come that way . I have one laying around. does it need to go up aganst motor and collet tight aganst it . or spacer needed ? want to put it in right if im gonna use it
thrust bearing ?
I use a piece of paper between the collet and thrust bearing to get a little end play before tightening everything up.Mike Chirillo
www.capitolrcmodelboats.com
I generally do not use thrust bearings. True, I generally use high-quality motors, but even most Limited motors have decent bearings designed to handle axial loads just fine. One problem is that many of the "thrust bearings" sold for boats are not designed for high rpm use. Too, they are also more prone to rusting or foreign material damage which will increase drag considerably. But if you want to use one, make sure to follow the suggestions posted above or the bearing will be either useless or will actually reduce motor performance.
BOCA sells stainless thrust bearings if you want them.
I use them on most everything. However, just last night I was inspecting my 1/8 scale and saw that my 8mm thrust bearing had disintegrated. Not sure if my gap was wrong or if as Jay suggested I simply exceeded the design parameters of the bearing. Annoying.Noisy person
ok hope i did this right put it on shaft slid it tomotor case put on collet pulled it back enough for a paper gap between case and bearing collet is just touching it . i have never used one before they dont have any instructions on how to set it up with it
