Power supply?
  • raptor347
    • Jul 2007
    • 1177
    You know how solid the Bulldogs are. Get an RDC-90.
    I've been running one for 10 years with as many as 4 duo's running on it at the same time.
    Brian "Snowman" Buaas
    Team Castle Creations
    NAMBA FE Chairman
    • T.S.Davis
      • 6266
      They should call them Bulletproof instead of Bulldog.
      The only hiccup with the bulldog is that of you plug into a GFI it will pop it every time. Wonder if they got passed that problem.
      Noisy person
        • 7512
        http://forums.offshoreelectrics.com/...Y-47-AMP-by-HP
          • 7512
          By the way, if anyone is looking for power supplies and wants to get them from Robert (and can wait till the Nats in Michigan), I could bring them along with me and save shipping costs.
          • 427srule
            Racer
            • 188
            What's out there that's great?
            I bought an 24v1200watt Efuel and I hate it.
            The one 30amp circuit is fine but the other 3 are only 10 amps each. Meaning that if you crest 4amp charge rate on a (2)4s packs it resets itself without any warning or indication. Pretty disappointing. Yeah I know, supposed to do the math before you buy but it should have worked. It's going back.
            What else is out there though? Looking to run 4 chargers with 2 ports each at 7 amps plus regularly. So maybe 1000watts continuous plus or minus.
            Terry,
            Check this one out
            I have two 24v/47amp units. They work great
            Mike
            • T.S.Davis
              • 6266
              They have 24v@100amps for $140. That's super cheap.
              Noisy person
              • T.S.Davis
                • 6266
                Just sent Robert a note.
                Noisy person
                  I had a Feather Merchant, the 42 amp unit. I sold it and now use one from LipoPower and it does not shut down in the heat like FM did....
                  Originally posted by 427srule View Post
                  Terry,
                  Check this one out
                  Mike
                  • LiPo Power
                    DJI Drone Advanced Pilot
                    • 3678
                    Terry, I have what you need.
                    Pm replied.
                    Canada
                    • T.S.Davis
                      • 6266
                      I finally did order one of these from Robert. 24volt 75 amp beast. If that can't hold me it's hopeless.
                      Taking the Efuel back this weekend. Disappointed with that turd. Looks cool though.
                      Noisy person
