water cooling question
  • Simon.O.
    • Oct 2007
    • 1611
    That looks to be a 42mm x1.2 or 1.4 Kyosho prop on there. If so that is where your problem is. I run Kyosho props and octura plastic props and can tell you now that motor is better suited to a smaller octura. i would go for a 531 to start and then look at a 534. My rigger is better on a 431 than a 531 and that is running a superstock can (27krpm).
    As the others have said, the one pickup behind the prop should be sufficient.
    Octura plastic props are a few dollars each and will let you do a lot of testing to find a prop size to suit.
    Down prop and let us know how you go. Do not keep overheating your gear, you will kill it, trust me I have done it.
    • vdubsport
      • 42
      just started to order parts from steve and learning as i go. as for the car esc it was just something i had laying around,(right know my budget is very limited due to to 2 major back surgeys and a 3rd on the way in the next two weeks, also living in phoenix its hard to get boat parts untill i found this site) on a better note some recent pick ups from ose were a octura x427 and a x632 for my 20 inch mono project also some micro hardware, the boat in the pictures was just taken off the shelf to help me learn how to set up a wire drive system before i started to chop up my wooden mono. The prop on this boat is the stock kysho prop that came with it.
      thanks, Jeremy
      Last edited by vdubsport; 07-18-2008, 07:17 PM. Reason: didnt like the way it was worded
      • vdubsport
        • 42
        wen u say binding where do u see that at ? here are some pics at the coupler. do u know of any halfway decent esc for a decent price.
        • vdubsport
          • 42
          sorry never mind the angel its at is from the original angel the stock stuffing tube was put in
          • SweetAccord
            Speed Passion
            • Oct 2007
            • 1322
            Here on OSE the X-Power are very affordable. . . . .How good are they? Dunno. I asked that once and no one ever replied. . . . . . .
            • vdubsport
              • 42
              one more quick question on installing hardware on a mono is there a tural or some other site that shows how to install micro hardware? stuff like the best way to set up the stuffing tube and what angal the strut should sit?
              • vdubsport
                • 42
                also how the set up should exit the hull into the sturt?
                • crabstick
                  • Jul 2008
                  • 955
                  i like to have the stuffing tube a few mm above the keel line, depending on the size of the boat and the props im likely to run i also offset the shaft to counter prop torque
                  Also i would run the tube with as little bend as possible and after the shaft exits the transom should run almost parallel to the keel
                  heres a good link for ya
                  Matt.
                  www.rcboats.co.nz
                  • vdubsport
                    • 42
                    thanks for the link, one more quick question if im using a strut in stead shaft what do i use in between the back of the boat and the back of the shaft? and do use teflon liners, and if so do u run it all the way throught the back of the shaft?
                    • crabstick
                      • Jul 2008
                      • 955
                      i normally run the tube right through the strut, i run my homemade bearing cartridges and no teflon
                      Matt.
                      www.rcboats.co.nz
                      • vdubsport
                        • 42
                        thanks again for the info
