Hello All,
I am building a TFL 36 inch mono, my first build. My other boat is a Revolt.
The Revolt has the water pickup on the right side of the rudder, works really well when turning right, or going straight, which is what we do most of the time. Does not work so good when turning left.
The Ariane I am building came with a rudder that has the water hole on the left, close to the prop. I do not understand why they do this. Don't they know we turn right? Do they turn left when racing in China?
So I was looking for a duel inlet rudder because the pond water gets warm here in Florida in the summer and I wanted to run separate cooling for motor and ESC. The only rudder I can find to fit has the duel inlets on the left side.
Does prop wash help push water in the left side inlet or do I need to keep looking and find a duel inlet rudder that fits with right side inlets?
The other option is to put a water pickup in the bottom of the hull, flush mount or get a brass tube of the back of the transom. If I used the flush mount I assume it would have to be back as far as possible and slightly right of keel. I do not like the brass tube because of drag.
Please advise, thank you for your time,
Varooom
BTW: Shouldn't someone tell TFL we need the inlets on the right? What are they thinking?
Varooom
Sorry Varooom, been staying up too late last night working on my boat, what else?! , really didn't know what I was writing. haha, of course it is a different rudder, and you are probably not using Speed Master.
