wher to get bulk .187" r and L hand flex?
  • wolf IV
    • 1050
    Cant remember where I got my bulk right and left turn flex drive from? help me!!! Hmmm... maybe I asked Steve?
    http://www.youtube.com/watch?v=e-npTLBHefY
  • wolf IV
    • 1050
    sure has changed around here...
    • longballlumber
      • 3417
      With 10 minutes and some creative Google searching I found this part number for Octura brand .187 cable (available in Left (std) and Right lay) OC187L-240 (20′ x .187)
      I then quickly searched on the part number listed above and found the item at Rocket City Racing...
      I would send an email directly to Steven to see what's actually available from Octura.
      Later,
      Ball
      • wolf IV
        • 1050
        I tried Steve first with no avail. I asked without researching figuring other would know off hand as I cant remember where iI got my stock from before. Ill check out your links fore sure ! I appreciate doing the search
        • Jeff Wohlt
          • 2740
          I make them still.
          www.rcraceboat.com
          jwohlt5362@yahoo.com
          • wolf IV
            • 1050
            Payment sent Jeff
            • Jeff Wohlt
              • 2740
              Cable is easy...it is the stubs you want that is the hard part but I got them covered. Will be making them next week for you. Had to order the SS shaft.
              www.rcraceboat.com
              • Fella1340
                • May 2013
                • 1025
                Jeff, I need to make a custom 1/4" drive stub end to accommodate a unique stinger. I spoke to you awhile back and you weren't making them. I am hoping to machine it myself but I don't know type of stainless to use. I can get it heat treated through another hobby I have. If you could tell me the correct stainless and Rockwell hardness it would be appreciated as I will be needing it within a few weeks. If this is a trade secret I understand. I have some 440c SS in square stock I could machine round if this is suitable but would prefer to use the correct stuff. If you are by chance are making 1/4 drive flex shafts I would be happy to just order it from you. Thanks for any help you can give. Jeff
                • Jeff Wohlt
                  • 2740
                  I just do not have enough demand. Order some 303 SS and you will be set. No need for hardened...just harder to work. Only reason you would ever need a hardened shaft is for roller bearings in a strut.
                  www.rcraceboat.com
                  • wolf IV
                    • 1050
                    Sounds good! :)
                    • Fella1340
                      • May 2013
                      • 1025
                      Thanks Jeff, glad to hear I don't have to bother with heat treating. There's worse things out there to machine than 303. My local supplier stocks it, hopefully in a small enough diameter! Thanks again.
