Gas engine ?
  • l8rg8r
    • Nov 2011
    • 39
    Gas engine ?
    I'm building a large mono hull with a gas engine. On the motor mount what will happen if i don't use rubber isolators and mount the engine with solid mounts right on the stringers
  • don ferrette
    • 1093
    The boat will vibrate itself to death, rubber isolators are a MUST on larger IC engines. Also a solid mount on a large boat hull will create a tremendous amount of hull noise, monos are the worst in that regard because of the inside shape actually magnifies the sound.
    - IMPBA Hall of Fame -
    - IMPBA Hydro Technical Director -
    • l8rg8r
      • Nov 2011
      • 39
      Ok thanks Hess I need to find some isolators
      • don ferrette
        • 1093
        Here ya go-
        Bruce is a good guy to deal with and very reasonable prices.
        • gsbuickman
          • Jul 2011
          • 1292
          Come on Bro, show the guys some pics of that Prather mono your macgyvering on . you gotta love the 80's pastel pinstripe paint job ...
          • l8rg8r
            • Nov 2011
            • 39
            image.jpgimage.jpgimage.jpgimage.jpg here's a few pics of my 42 inch mono I believe it's a Prather but not sure what it is other than cool if you know make or model I would love to here it
            • gsbuickman
              • Jul 2011
              • 1292
              Here's some pics of the 80's pastel twins i took when you brought them over Bro :-) . they're so Miami Vice ....
              • gsbuickman
                • Jul 2011
                • 1292
                Hopefully Rick will show us some pics of his motor project that he's working on for the mono. I forget what motor he said it was, but I know its a watercooled 5 HP weedeater style motor, with a lightened , balanced flywheel.
                As far as the shovel goes. It's hand built glass over wood and not something I want to run very often, so i'll keep it vintage simple. I am thinking of a 700 class Cordite with a 60v/50A Astroflight 207D on 4s pushing the 3/16 flex & Octura 1460 prop. Its primarily a shelf queen, so its all good. I wanna see what Rick cooks up to make he mono go ..... :-) .
                • Chilli
                  • 3067
                  Also, every screw that isnt Locktited will vibrate loose. On gas boats you have to keep an eye on loosening hardware even with rubber isolators.
                  Mike Chirillo
                  www.capitolrcmodelboats.com
                  • l8rg8r
                    • Nov 2011
                    • 39
                    Here is a pic of what I've got done so far I milled the jug to except my redneck water jacket and lightened the flywheel I goofed on what engine I had it's not the 044 it's a stihl fs or fc 44 that's a big diif so hp I have no clue but it's 30cc I wish it was the 044 that's a 70cc with over 5 hp thanks for the lock tite tip I lock tite everything alway it's cheap insurance
