ESC Shrink Tubing
  • Skunk Works
    • 251
    ESC Shrink Tubing
    Hello Everyone,
    Wondering what is the best to use for shrinking speed controllers. I have a board that is about 1 1/4 wide, and I added a cooling plate to it also.
    Would the battery shrink tube that Steve sells work OK?
    Thanks!
    Scotty
    Stay in front and don't get sprayed!
  • deestingray
    • 57
    Personally I cannot see why battery shrink wouldn't work, it only has to hold the cooling plate on and protect it against accidental water splashing. I use the same type of shrink that you do wires with, you can buy it up over 2 inches in diameter and it doesn't shrink a lot lengthways which enables you to cut it a bit longer than the board and jam some silicone in the ends to make it water resistant, it is also a lot more pliable than the battery shrink imo.
    • Lakefrontlivin
      • 232
      HI,
      I ended up buying a bunch from Steve and found the 2 1/8" one to work best for me. I have a Phoenix 125 with a couple of cooling plates on it.. Here are some pics. My esc was 1 1/4" wide and 3/4" tall
      Hope that helps..
      Tom H .
      • Lakefrontlivin
        • 232
        Scotty,
        Where are you located in NH?
        If you're close maybe we can run together sometime. I have a waterfront home to run, so that wouldn't be a problem..
        Later,
        Tom
        • Skunk Works
          • 251
          Thanks for the replies. I will use the battery shrink tubing.
          Tom, I am in Fremont. Going to Deering Lake in a couple weeks on vaca with the family. Where are you?
          Have a good one!
          Scotty
          • Lakefrontlivin
            • 232
            Scotty,
            I'm located in Barrington.. Next to Rochester or Dover. Do you have an actual hobbyshop ?
            Tom H .
