Flooded tube question?
  • Mattwarner
    • Aug 2011
    • 495
    I am just building a Mono with a flooded stuffing tube, how much adjustment is recommended?
    I have some carbon tube which is 10mm ID and using 1/4 brass so this only gives me 4mm of adjustment, I aim to try and get it set spot on but will 2mm either way be enough?
    I think I know the answer but seems a wasters not use what I've got!
  • siberianhusky
    • Dec 2009
    • 2206
    FWIW my 29" mono has about 4mm up and down after I re-did it, I've never moved it down, only up as the prop sizes have increased, only gone up about 2mm running a 46.5mm prop. Started out with a different motor and 42mm prop.
    • runzwithsizorz
      • Jan 2009
      • 901
      Not sure how much there would be to gain with only 4mm of travel. I used a 1/2" piece of copper pipe, crimped on one end to make it oval/elongated and got nearly 11mm of adjustment.
      Would you work all day on your cars engine to install a part that would only get you 1,or 2 horsepower? That's a waster mate.
      Get a larger flood tube.
      • martin
        • 2881
        I know some use 16mm o/d carbon tube giving 14mm I/d.
        • Doug Smock
          • 5359
          Here's a nice clean alternative to a tube. DSCF5461.jpgDSCF5468.jpgDSCF5528.jpg
          MODEL BOAT RACER
          IMPBA President
          IMPBA 19887L CD
          NAMBA 1169
          • Mattwarner
            • Aug 2011
            • 495
            Think this is going to be a better size and maybe I can still step down to the 12mm OD tube
            • properchopper
              rcgoatbuild@snotmail.com
              • 7708
              Originally posted by Doug Smock View Post
              Here's a nice clean alternative to a tube. [ATTACH=CONFIG]110746[/ATTACH][ATTACH=CONFIG]110747[/ATTACH][ATTACH=CONFIG]110748[/ATTACH]
              I'm putting this configuration in my "great idea" file. Thanks
              • runzwithsizorz
                • Jan 2009
                • 901
                Was hoping you'd chime in Doug. Didn't you use a large CF tube on your big Sniper?
                • Doug Smock
                  • 5359
                  Hi Todd,
                  You may be thinking about Tyler, Peter Z., or ?? I've done it that way in every mono I've built with a irrigated shaft alley. I just like that set up.
                  Thank you sir, and you're welcome.
                  MODEL BOAT RACER
                  IMPBA President
                  IMPBA 19887L CD
                  NAMBA 1169
                  • Mattwarner
                    • Aug 2011
                    • 495
                    Agree that's a great idea if I had stringers I would definitely do that!
                    • runzwithsizorz
                      • Jan 2009
                      • 901
                      [QUOTE=Doug Smock;546953]Hi Todd,
                      Gosh I thought is was you. Kevin used a cf tube on a Sniper build,--- http://forums.offshoreelectrics.com/...2&d=1356814353
                      IIRC the one I am thinking of in a Sniper was painted yellow, the cf tube was huge, and only 6" or 8" away from the transom. It was that one that inspired me
                      to build my Titan 33 with a flood chamber. With motor, prop, and water surface changes it's great to be able to make these changes to a *larger* mono hull.
                      To the OP, what hull are we talking about here?
                      Thank you sir, and you're welcome.[/QUOTE
                      three
                      • Mattwarner
                        • Aug 2011
                        • 495
                        Same hull Titan 40 (33")
                        Going to order some larger tube tonight
