wondered if 1700-1800kv motor with 180a esc and two 6s 5000mah in paralel would be to much for a 32inch vee hull was thinking a 447 3blade just trying to get a idea for good runtime and power i might be way off be easy on me running a x440 now on a 4s looking to upgrade soon this spring
would a 1700- 1800kv motor be a good choice for a 32 inch v hull
Yes to much. Those RMP ranges are good for 4S. a 1200-1500 KV would be best for 6S. Kind of a small boat for that much power. BTW on 6S with an 1800 KV Motor and a 447/3 you are theoretically capable of 75mph+ and the magic smoke. (Don't do it!)
A 1200 Kv motor on 6S with the x447 will theoretically get you around 45-50 mph. But the run time will be quite long because the amp draw is low. It depends on what you want out of the boat, 55 mph is a lot for most 32" monos.
1800 kv is to much for a mono that size on 6s (sportrunning) but would surely go for more then 1200 kv on 6s
1500-1600 KV
and personaly i would go for a smaller prop:3 blade :42mm 1.4-1.6 p or a 45 mm 2blade
a 40mm can /74-82mm
150-180a esc
i prefer a little more rpm and smaller prop then swinging a big prop/low rpm's ...
but that's me....
i agree, i prefer smaller props, because i don't like the effect bigger props have on a hull. i feel like the handling is compromised, especially on a v hullOriginally posted by iop65 View Post1800 kv is to much for a mono that size on 6s (sportrunning) but would surely go for more then 1200 kv on 6s
1500-1600 KV
a 40mm can /74-82mm
150-180a esc
but that's me....
if i run ose. setup the 4082 and 5s would that be all around setup for playing and runtime will still be running packs in paralel kinka wondering about 6s being overkill . the 180a esc says it will do 6s but i see alot of people saying on 6s that you cant run bec ? i dont want to burn any thing up it cost to much. almost got enough saved for batts once i make up my mind for sure
pugman2
I'm in the same school as ipop65 & Heaving Earth in regards to props.
But with the Seaking 180A ESC, I race, using the BEC on 6s in a 40" hydro & a 41" mono . No Worries. So do many others.See the danger. THEN DO IT ANYWAY!!!
