What to seal bare wood transom with?
  • Varooom
    • Nov 2013
    • 97
    Hello all,
    I am progressing on my TFL Ariane 2 cf build. I am ready to send the hull out for some small graphics and clear coat.
    Before I do that I noticed the inside of the hull transom is bare wood. I would like to seal that with something before paint.
    Is there a marine grade urethane I can use?
    I thought about epoxy but it is too thick.
    What should I use to seal up my plywood
    ransom?
    thank you for your time,
    Varooom
  • jkr
    FE Addiction
    • 582
    You can use epoxy for layup propose.
    Its thinner than normal epoxy.
    • photohoward1
      • 1781
      Thin it with a little Alcohol.
      • rickwess
        • Apr 2013
        • 777
        Laminating epoxy works well. While you're at it, a layer of CF wouldn't hurt........but I do like to overkill things.
        One tip I learned from the guy who built my full scale boat is to make sure the wood is sealed inside the transom through holes.............yes overkill on a RC boat Use epoxy for that as well.
