? what prop for Mean Machine?
  • Lakefrontlivin
    • 232
    Looking for suggestions for a prop to try on my mean machine cat.
    It has a CC Baracuda 125 ESC and 9Xl motor with 4900 Mah packs in Parallel. they are 2) 4S1P 25C packs.
    I tried a 440/3 blade prop and it wasn't to bad.. just wondering if there was a better prop to try? Thanx, Tom H .
    Last edited by Lakefrontlivin; 07-13-2008, 05:35 PM. Reason: corrected battery setup info...
  • ReddyWatts
    • 1756
    X640 on 4s with atleast a 120 amp ESC. This setup should use around 90 amps.
    ReddyWatts fleet photo
    • Lakefrontlivin
      • 232
      Thanx for the reply,
      I have a 640 believe it or not..
      I'll have to try it out :)
      Thanx again.
      Tom
      • ReddyWatts
        • 1756
        I see you added some info. Are you running on 2s or 4s? You series or parallel your lipo's? The Fiegao 9xl motor runs well on 4s. It should run in the mid forties.
        • Lakefrontlivin
          • 232
          Hi,
          I'm running 2) 4S1P packs in Parallel.. Am I correct when I say 4S2P ??
          I only have a 646 prop which I tried.
          Very fast !!
          A little rought out there right now.
          I'll throw the GPS in it a little later when the lake smooths out.
          Tom
          • Eyekandyboats
            • 1935
            las time i ran a 9XL hacker was when NIXX were main stream and i ran a x642 with a bit of modifications to it.
            with lipo your should be able to run a 642 like no bodys business and should be able to prop up even more
            keep the strut a bit hi for a run or two. if it cavitates then drop it until good.
            by saying 2s2p i think he means 4s1p. 2s on a 9XL will do pretty much nuthing with a 440
            EYEKANDYGRAPHICS
            www.rclipos.com
            • Lakefrontlivin
              • 232
              Sorry for all the confusion ??
              The packs say 4S1P 4900 Mah 25C on them and I have them wired in Parralel..
              Do I only need one pack to run the boat? I would like the longer run times. I need at leat two minutes to run withthe Nitro guys..
              Thanx, Tom H >
              • ReddyWatts
                • 1756
                For the 9XL with a X640 prop using around 90 amps on the 4900mah 25c, one pack will give you 2.5 minutes of run time and two in parallel will be 5 minutes.
                Use a clock to time your run times or a LVC. Do not run them for more than 2.5 minutes on 4s1p and 5 minutes on 4s2p. That is 80% of your battery capacity. Keep an eye on your temps.
                • Eyekandyboats
                  • 1935
                  Thanx, Tom H >
                  no you need both packs. your boat should run about the 3-4 min mark if you have it setup fast!!!
                  to get longer run times will require you to either prop down. or get two more batteries
                  EYEKANDYGRAPHICS
                  www.rclipos.com
                  • Lakefrontlivin
                    • 232
                    Thanx guys for the info. I appreciate it !!
                    I wanted to keep both packs in the boat just to balance things out as I have a pack in each Sponson I guess you would say.
                    Here are some pics of the bats.
                    I'll get some pics of the boat soon.
                    Tom
                    • Rex R
                      • 1007
                      the 440/3 is a pretty good prop for an offshore race(4 minute enduro)(I have a similer set-up) you will need to moniter your motor/pack temps if you 'prop up'
                      • Eyekandyboats
                        • 1935
                        okay so you are running 4s2p!!
                        man it gets confusing.
                        4s1p ( says on pack) combined in parallel becomes 4s1p.
                        4s1p combined in series becomes 8s1p
                        EYEKANDYGRAPHICS
                        www.rclipos.com
                        • ReddyWatts
                          • 1756
                          The Mean Machine runs best if you raise the bottom of the strut up 1/4 to 3/16 of an inch above the bottom of the hull.
                          • Lakefrontlivin
                            • 232
                            That's about where it is right now. Seems to run ok .. Maybe a little light in the nose..
                            Didn't get a chance to run it again tonight as the lake never really was smooth enough.. Thanx guys. :)
                            Tom H .
                            • Rex R
                              • 1007
                              heh sounds like race water :-).
