1527 Neu quest
  • dasboata
    • Dec 2010
    • 3972
    1527 Neu quest
    On this motor The end bells are glued in. I find that strange, what do I use for glueing them back,, silicone? that is what it looks like thanks chris
    Must be an older version. Most use CA to glue the end bell on. This motor needs a thrust bearing on the PTO end.
    • dasboata
      • Dec 2010
      • 3972
      Got ya thank you !! I am assuming no play on the thrust bearing between the collect and the housing thanks chris
      • RaceMechaniX
        • 3024
        Chris,
        Some of the motors had loose fitting endbells and are also subject to thrust forces. Some loctite or silicone helps secure and dampen them.
        Tyler
        Tyler Garrard
        NAMBA 639/IMPBA 20525
        T-Hydro @ 142.94mph former WR
        • nobbiworld
          • 170
          I have 2 the same. Was looking at drilling and tapping the end bell as per latter models. Is this a good idea? Thanks Steve
          • jcald2000
            • 786
            I put 3- 256 screws in mine.
            • nobbiworld
              • 170
              Thanks Jim
