Kyosho Hurricane
  • egneg
    • 4664
    Kyosho Hurricane
    I have modded this boat with an OSE 700SC and a Jetti navy 600 on 12 cells with a detongued X645. I then changed the steering servo to HS-645mg to deal with some steering issues. It still spins out if I am not careful. I have made some longer turn fins but haven't had a chance to run it yet. Here is a video - if you have any suggestions to improve this boat that would be great.
    P.S. I need a new video person - my daughter sucks at it.
    IMPBA 20481S D-12
  • Diegoboy
    Administrator
    • Mar 2007
    • 7247
    I'd remove the steerable outdrive and install a strut and rudder.
    • dirtysouth31
      • 514
      • SweetZ28
        • 1322
        Nice boat.... looks like she is not into boats could not stand to film it for more than 1 min! LOL
        WWW.PPRSLOTS.COM
        • Diegoboy
          Administrator
          • Mar 2007
          • 7247
          What radio do you use?
          Try reducing the steering rate or EPA (end point adjustment)
          • Diegoboy
            Administrator
            • Mar 2007
            • 7247
            Do you have a pic of the transom with the turn fins installed?
            • egneg
              • 4664
              Hi Diego - I have limited the steering and things seem fine for the most part but every now and then it spins out. I don't have any new pics with the longer turn fins on the transom yet but will try to get some posted . I was trying to hold off on the strut and rudder until I put the BL setup in it
              IMPBA 20481S D-12
              • Diegoboy
                Administrator
                • Mar 2007
                • 7247
                I'm curious to know if the fins are installed vertical or Perpendicular to the bottom angle.
                • dirtysouth31
                  • 514
                  Diego ment perpendicular to the blow hole!
                  • egneg
                    • 4664
                    Vertical
                    IMPBA 20481S D-12
                    • ChaKane
                      • 131
                      Your turn fins need to be perpendicular to the hull so that when the boat is turning, the fins are vertical in the water. If they are at an angle in the water as the boat is turning, this will cause problems by the fins raising the transom during the turn, lifting the prop from the water. Mind you, with the cat hull you have they don't roll anywhere near as much as a mono, so the vertical angle may well suit that hull type.
                      • Diegoboy
                        Administrator
                        • Mar 2007
                        • 7247
                        Sorry Avanti27offshore, I had to borrow your image.
                        Egneg, try installing the turn fins like this...
                        • egneg
                          • 4664
                          Thanks Diego - I will try that.
                          The blow hole?
                          IMPBA 20481S D-12
                          • Diegoboy
                            Administrator
                            • Mar 2007
                            • 7247
                            Here is your video I promised!
                            Egneg - Kyosho Hurricane
                            • egneg
                              • 4664
                              Thanks Dieago - you could have saved me some embarrassment and not used the last bit.
                              IMPBA 20481S D-12
