Mean Machine new build help please
    Originally posted by mekzoid View Post
    Oh Jet lag is always fun!
    That is still doable, 5s2p. How do you work that? Do you just run a y cable off both black and red off the esc?
    you would use an adaptor like the one down the page: http://kintecracing.com/
    It is easy once you start using bullets on the batteries.
    • mekzoid
      • Nov 2011
      • 120
      ahh thought so. Cheers mate:)
      • mekzoid
        • Nov 2011
        • 120
        Anyone else have any input? :)
        • Heaving Earth
          • 1929
          Nowadays I'm running a castle 1515 1y on 5s2p and an m642. Hitting 60mph
          • Heaving Earth
            • 1929
            Keep in mind, the mm is really a 60mph boat tops. If you want to go faster it takes meticulous tuning or a hull better suited to higher speeds
            • mekzoid
              • Nov 2011
              • 120
              Thanks for that Heaving Earth,
              What Hull would you recommend for higher speeds?
              • Heaving Earth
                • 1929
                Sprintcat
                • mekzoid
                  • Nov 2011
                  • 120
                  http://www.offshoreelectrics.com/pro...rod=Aero-sc-40
                  Is that the one?
                  Its so hard to pick a hull as I really don't know which one will suit me the most. I am after speed and stability in turns. Something that is nice and strong and eventually will run 70mph+. First build will do 60mph
                    As mentioned above the MM is not a large boat. It is not going to be very useful at 70 mph. I'd recommend the Avenger 36 instead. It has the same bottom as the SprintCat but is a lot easier to tape, has much better access and more scale-like looks. I run a SC on 6S but the Avenger wasn't available when I built it. For 70 mph I recommend 6S - and a motor with a Kv around 1500. Lower amp draw and longer run times .
                    • mekzoid
                      • Nov 2011
                      • 120
                      Thanks fluid, Would you suggest the same hardware mentioned above?
                      Id still go for the neu 1515 1500kv I think, unless you could suggest a better motor for the bigger hull?
                      Might have to do twins?
