Hextronik 120ESC - Good or bad or just ugly
  • showstoppercat
    • May 2007
    • 95
    hexTronik PRO 120A BESC w/ PC Programmability
    Speed Controller Features
    High rate (10 KHz) switching (PWM)
    3 to 6 Li-poly cells with receiver.
    Dynamic braking ensures prompt prop folding.
    BEC (2.0A) provides power to receiver and servos.
    Over temperature protection.
    User programmable Features.
    Low-voltage protection - Programmable
    Cutoff can be programmed for motor stop or reduced power.
    Brake Type.
    Throttle Range.
    Timing Advance.
    Safe “power on?arming program.
    Low torque “soft start?prevents damage to fragile gearboxes.
    Auto shut down in 4sec after signal is lost or radio interference becomes severe.
    Microprocessor controlled.
    Programmable rotation.
    Specifics;
    This BESC has an extremely smooth throttle curve and excellent programming features. it is oneof the best quality BESC coming from China right now.
    Item comes with a 12 month warranty
    Max Load : 130A
    Max Voltage : 6 cell 25v
    BEC 2A
    Please be advised that BEC should be dissabled when more than 3 cells are used. To dissable BEC remove the middle RED wire from the reciever wire.
  • ReddyWatts
    • 1756
    They are an "ok" sport/economy controller. Many people on this forum have used them with no problems. Some had cogging issues, depending on the motor being used.
    ReddyWatts fleet photo
    • ED66677
      • 1300
      mine just smoked after first run, was using Feigao 8XL, 18 Nimh cell, gearbox pulling less than 80 amp burst!!! duno what went wrong but for sure motor still doing fine and is not the cause of fire!
      Emmanuel
      • showstoppercat
        • May 2007
        • 95
        Any recommendations on setting up a Drifter M (BL) motors esc props to consider would like to push the 62mph barrier (100kms)
        • Stealth Assassin
          • 610
          I personally have had better luck with the turnigy 100a hv after a fan was Installed and program card.
          • ReddyWatts
            • 1756
            showstoppercat, FeCalc estimates
            Neu 1521 1Y
            6s1p
            X640 prop
            80 amps
            32000 rpm
            If someone has run this setup, please chime in.
