Offset can work in shallower vees or stepped hulls, but IME deeper vee hulls will only chine walk worse with much strut offset. It's all about the physics of course, with offset prop lift upsetting the delicate dynamic balance on the keel of a vee hull....
BTW your English is just fine Mark!
Rick - center the shaft line over the keel. The hull has a natural tendency to go straight as directed by the keel line. You want the prop thrust (as dictated by the stinger location) to be in agreement with this. As has been found, many hulls aren't symmetrical so use the keel line as the center of the hull regardless of what the ruler tells you.
