Where is this water coming from??
  • agentorange
    • May 2013
    • 238
    Where could the water be coming from? I have a HK Genesis and every time I run the boat its filling up with water. I would have to say about a cup or more. I replaced all of my water coolant lines and resealed my stuffing tube. I have also sealed the lower part of the stuffing tube to rudder. I ran it today and there was still water in the hull after the run. it wasn't as much but it was still a good amount. I just cant figure out what the water is coming from.
    Post some pictures of the boat and setup in it.
    It may be coming in at the stuffing tube end where flex shaft and coupler connect,
    If it is just add a small piece of water line there and it should stop most if it there.
    Also do a pressure test on the lines and motor cooling jacket and esc cooler to,
    Use a syringe or something like that filled with water to pump through it from water pick up line to the exit,
    Than block the exit port with you finger or something and see if it holds the water back and look for leaks.
    You can also do a tub test and see if anything show up.
    • TOFTS
      • Aug 2013
      • 15
      Put a piece of paper towel around your motor to see if the water jacket is leaking?
      • Southwest
        • 274
        Cooling jacket , where rubber rings are supposed to seal the jacket. I'd take hardware off and seal area of turn fins and outside of strut. Check seam of boat and tape down cover.
        • ron1950
          • 3082
          i had a pursuit that always seemed to leak just a little and could not figure where it was coming from.....thought it was the stuffing tube but couldn't prove it....changed the flex the other day cause the old one showed some wear and sure enough...no more water
          • gsbuickman
            • Jul 2011
            • 1500
            Have you filled the stuffing tube with marine grease, to stop any water pumping by the flex shaft. ?
            • Chilli
              • 3204
              Check for a cut in the cooling lines. Especially around fittings. They can be hard to detect.
              Mike Chirillo
              www.capitolrcmodelboats.com
              • madmikepags
                • Aug 2012
                • 1371
                do a pressure test on your lines, don't blow into it you cant create enuf pressure, use a large 60cc syringe (you can pick one up at any pharmacy for a buck or 2 w no needle) fill it w water and attach it to the intake hose, fill the system w water than hold your finger ove the output hole. Then apply pressure to the system if there are any leaks it will show. Also check the seams on the hull these are annoying because you can get buckets of water in your boat thru a cracked seam that you cant even see.
                We call ourselves the "Q"
                • b0atnutz3
                  • Feb 2010
                  • 176
                  Do what Mike said. I was at a race yesterday with him and that is how I found my pin hole leak on my cooling line from rudder to ESC. Lots of water for a short amount of time.
