Doesn't seem right?
  • Timmy
    • May 2013
    • 73
    Doesn't seem right?
    So i'm looking at this boat,about to put things together and I realise that the pre cut servo mount only holds a micro servo, for a boat of this size (660mm) that just doesn't seem right. Now I have plenty of micro servo's but I had planned to use the kick ass standard servo I have sitting next to it. What do you think is more appropriate?? Is it good enough to cable tie the big one down or should I buy alloy mounts?
    "Speeds just a matter of money, how fast do you wanna go?"
  • siberianhusky
    • Dec 2009
    • 2206
    Depends on the servo, I run a JAE .12 nitro rigger with a Hitec HS-85mg servo, no issues what so ever, it's a fast boat! Crashed many times, hit turn markers etc, still the original servo from 3 years ago.
    • Timmy
      • May 2013
      • 73
      Is that a 9g servo? I've got lots of different types of them. I am using one in a ridiculously fast sea rider. doesn't seem right on this one though. Look how small it is in the boat! How big is the rigger?
      • Timmy
        • May 2013
        • 73
        Offshore electrics have some cool servo mounts.....
        • properchopper
          rcgoatbuild@snotmail.com
          • 7708
          I just encountered a situation not unlike yours on a customer build [Mini Sniper]. The customer sent me a servo and mount. I then discovered that there's a size difference between a Mini Servo and Micro Servo.. I was sent a Micro Servo (which spec-wise was quite strong enough) but the mount was for a Mini Servo.
          I searched and searched for a Micro Servo mount but not finding any finally modded the Mini Servo mount. Took a bit of fiddling !
          • gsbuickman
            • Jul 2011
            • 1500
            I am in the process of trying to put a steerable outdrive on a 21" rigger. At the moment its got a full size servo in it, but I think its going to get changed to a mini servo to make a more workable space. I guess it depends how functional it is & what your comfortable with .
            • Timmy
              • May 2013
              • 73
              Problem solved! Rc boat Bitz in my hometown have the perfect alloy mount for the high torque standard size servo I want to use and they are very reasonably priced. It will be delivers by tomorrow!
