sv27
  • pugman2
    • 241
    sv27
    got a sv27 has a lipo cut off . changed radio to a gt2 cant get throttle trimm3d right now it wont go dow enogh to stop
    • 7512
    Not sure what a gt2 is, or that a 3D throttle trim existed...try reversing the throttle and then mess with the end point adjustments.
    • danielplace1962
      • 91
      GT2 is a fly sky radio. 3D is the ed on the end of "trimmed" it was a typo.
      You have several adjustment to channel 2
      One is the direction, FWD and REV. Second is the high end adjustment, End point adjustment. Third is the amount of brake or throw given when you backtrigger. Fourth is the trim for adjusting the idle or low side end point.
      With ESC's it can be tricky sometimes to get them initiated properly. Do you have the procedure for your ESC for setting up the ESC to your radio settings. You might need to start the setup from scratch or that might sometimes be faster than trying to get a new radio to mimic the old radio's outputs.
      Now what exactly is it doing?
