what hull should i choose for the following set up
  • Mattwarner
    • Aug 2011
    • 495
    Ok guys, ive got the itch for a winter build and fancy something for the following hardware which ive had lying around for a while, i have a load of 3s packs so 6s1p is what i am looking for, already built a twin 32" rivercat and single daytona (genesis) as well as a big mono, i want to build a single as twins get too expensive with sport running in mind, and was thinking of the following, 29" sprintcat, 41" fantasm, pursuit, overpowered 26" rocket,
    T180
    FC 3/16 strut (with the keg)
    M445 prop
  • flraptor07
    • Aug 2013
    • 2451
    T180
    M445 prop
    Looks like you got at least one of everything except a Hydro, build a mid sized Hydro like a Popeye or a Insane.
    • Mattwarner
      • Aug 2011
      • 495
      Popeyes looks good and available in the uk too!
      • flraptor07
        • Aug 2013
        • 2451
        I'll let you know how the Popeye is, I have one coming http://forums.offshoreelectrics.com/...rt-Hydro/page4
        • madmikepags
          • Aug 2012
          • 1371
          .40 whip!!!! 6s1p 1527/1Y
          We call ourselves the "Q"
          • Mattwarner
            • Aug 2011
            • 495
            Don't think they're available in the uk, ive seen a 24" H&M hydro anyone know anything about them?
            • Mattwarner
              • Aug 2011
              • 495
              Think I am gonnna take the plunge with a popeye, anyone suggest a good setup for sport running around 50mph on 6s1p? Was thinking of a 3674 1400kv and have a spare t120?
                More Kv than needed for 50 mph, and potentially more amp draw than the T120 can handle. A kV around 1200 would work much better in a hull that size, allowing a larger prop but keeping amps in check. I run a 1250 Kv motor in my 6SQ Sport Hydro and GPS close to 70 in race water.
                • Mattwarner
                  • Aug 2011
                  • 495
                  Thanks fluid I've got a spare m445 which I'd like to utilise but don't want to burn up an esc if you don't think it's up to the job, if I need a larger esc I guess I might as well go up to a 4074?
                    If you want 50 mph with an m445 the a Kv of ~1250 would work given good quality cells and setup. While on 6S that speed should be attainable with under 120 amps, I think you'd be happier with a 180 amp ESC and a 40mm motor.
