You mean you had no receiver, I see, I misunderstood! Anyway, depending on your luck, you really may not be able to return/refund those NiMh batteries, some stores state no return/refund on batteries simply because batteries can be misused or abused. In my opinion you should at least be able to exchange for equal value for other items. If you want to use lipos now, it is paramount that you get yourself a Lipo charger! Don't go the cheap way either, so do some research and see what they carry, this is an investment! And you will likely have multiple packs to charge at the same time before going to the lake, so getting two chargers are not excessive. Unless they carry dual or quad charger, but that might be too pricy.
Also for boat use you don't want hard case packs like those for RC cars/trucks, we prefer soft packs that are commonly used for helis or planes. If you have no choice, as someone said earlier, do not get the ones where you need to PLUG IN for the wires on the hard case. Get the direct wired ones.
best of Luck!
best of Luck!
