Hello everybody,
Just for chits & kicks I took my stock traxxas vilian iv out to play today. I ran it in the stock configuration with two 1500mah nicd packs, pushing the original plastic props. I wasn't expecting much, but I was kinda surprised when it couldn't even get up on plain.. It was heavy enough that it ran real wet & plowed around.
d.
I pulled it into shore and replaced the nicd's with a Gens ace 5000mah 40c, 2s1p bullet pack. The difference was night & day. It jumped on plane & was considerably faster, go figure....... What was surprising was the amount of water that it took on. It was dry inside the hatch but taking on water in between the hulls have been an issue with the villian's.
Has anyone had this issue or found a good solution to remedy it ?. I was pondering some of the pourable eurathane foam Steven sells here. A lot of people use it to fill in between the hulls of ul-1's. Any thoughts or suggestions. Thanks.......
d.
.....I pulled it into shore and replaced the nicd's with a Gens ace 5000mah 40c, 2s1p bullet pack. The difference was night & day. It jumped on plane & was considerably faster, go figure....... What was surprising was the amount of water that it took on. It was dry inside the hatch but taking on water in between the hulls have been an issue with the villian's.
