HK ARTR Sprint Formula3 Tunnel Hull Outboard
  • Snowride
    • 297
    Yep, running 4S and works very well however I have upgraded to a Turnigy 3450 motor which is rated for 4S and obviously your ESC needs to handle it. Stock motor may or may not like 4S, don't know as I never tried it.
    • er8sr
      • Apr 2013
      • 183
      Nice.. Any other tunnels available to run this motor on?
      • Snowride
        • 297
        Well I tried the 35mm x 1.7 CNC prop today but it did not fair too well. The wiring on the motor itself got so hot the terminal unsoldered. Not a big deal as no damage done. Good news is I got her to 49 mph and had more left but the pond was too small to really let her rip. I guess the moral of this story is stick with the 32mm x 1.7 CNC as this worked fine with no overheating. Max speed is around 46mph in this configuration which is way fast on this little boat.
        • Snowride
          • 297
          Just thought I would update this. The boat is still performing flawlessly with the setup I have. Only recommendation I can make is stick with the stock prop 23 x 1.4p. I have tries a few other cnc props but the wires get so hot the ternimals unsolder. One really nice boat overall after the mods are done running 2x 5800mah 2s batteries for a total output of 5800mah @ 4S on the motor. Run time is 10-12 mins. Loving it every time.
          • Stgdz
            • Jun 2015
            • 3
            how much room is under the sponsons? I've looked at this one as a tunnel but I only have 4s packs, 2200's specifically.
            I may be able to get away with it in a proboat but not sure on this one. HK also has a newer f1 tunnel hull.
            • Brandon Galles
              • Oct 2014
              • 36
              Very interesting design
              TFL Zonda Leopard 4082 1600kv, ML Boatworks PX335 FE Castle-Neu 1515 2200kv
              VS1 FE Castle-Neu 1515 2200kv, CRC 70" Outerlimits Zenoah 30.5cc
              • Snowride
                • 297
                1 3/4" from the battery tray to the semi transparent flex shield which gets taped on.
