Originally posted by launchpad
View Post
won't plane
Not to start any fires but Im going to disagree with kendt on the throttle trim. Set the trim to neutral or 0 and leave it alone. Ive programmed hundreds of these and never had to do that. Id imagine it may screw your neutral up. Set your throttle trim to neutral and follow the programming that I mentioned before which is same as Kendts but with out the trim deal.
the trim is on your radio, same deal as if your boats pulling one way a little bit and you adjust the dial, or if digital the trim numbers, to straighten out the steering.Originally posted by launchpad View Posti feel like a dummy.....what do you mean "return trim to neutral?
If your worried about anything, Pm me, ill give you my number. you can call me and I will walk you thru it over the phone. It takes less than 30 seconds
-Scott
ok now! Thanks to all who assisted me with this problem.What I found was causing the problem.I had program the esc for 6 cells and here I was trying to run 4 cells.Also once I calibrated the tx then added 6 cells to run and when I bliped the throttle it screamed.I have not had time to hit the water to see what the results are but I will try when our weather in proves. Thanks again to all. best regards
Good to hear that,
Hope it rides and planes out for you better than my hull was doing.
I just shelfed it and moved on but I still need to work on that problem with that boat hull.
Your talking about the OP hull right ?
They do look very long.
