Hi guys,
I'm new to boating but I've been in RC for a long time.
I got the apparition (single motor).
I took it apart and checked everything before my first run.
Now for the question. I've greased the flex and prop shaft with SKF bearing grease (probably not the best choice but I had it on hand), I've left the outside of the teflon tube ungreased of course.
I also left a bit of a gap between the flex and prop shaft (3-4mm) and adjusted the motor so that it doesn't push on the teflon tube in any direction. I also made sure the teflon tube isn't contacting the prop shaft (put a bit of hot glue where the teflon tube exits the bras tubing (motor side).
When I run it with the prop attached (not in the water) I can feel quite a bit of vibration and the brass tube gets warm near the prop shaft. It's the stock plastic propeller, I tried to balance it but my magnetic plank balancer it's accurate enough. The current draw is ~10A. Is this normal?
The shaft and teflon tube seem to be in perfect condition otherwise.
I just want to make sure before I put her in the water.
Thanks guys.
Thanks guys.
