offset ruders
  • sampit
    • Jul 2009
    • 466
    offset ruders
    Does anyone know were a complete offset rudder with z bracket can be bought from in Europe?
    I am looking for one for a H&M 36" cat
    looking like they are to to find anywere, never mind Europe
    rudder should be in the title not ruder, need to go back to school or use a spellchecker lol
    FC Cheetah TP4092 1600KV Dinogy 6s2p,Etti Envoy WE 3s, Rico Mono 31" T600 1400kv Dinogy 5100mAh 65c 6s1p
    Popeye Hydro T600 1400kv 6s1p
  • grsboats
    • 1011
    Horracing.com carries some types.Gill
    GO FAST AND TURN RIGHT !
    www.grsboats.com.br
    • sampit
      • Jul 2009
      • 466
      Thanks Gill that was my first place I look at, but cant find one with a picture
      I bought one from fightercat last year,but it never arrived
      • sampit
        • Jul 2009
        • 466
        I tryed converting the inline one I have, but i dont think it will be strong enought without a z bracket
        • StevenBryant
          • Nov 2012
          • 366
          • sampit
            • Jul 2009
            • 466
            Thanks, but that one is not big enough or strong enough, looking for one to run 3/16 cable. I have bought that etti one last year for a 24" hydro, its a great, but way to small for a 36" cat
            looking for one like this one
            • sampit
              • Jul 2009
              • 466
              Does any know if Speedmaster have them?
              RC Boats Australia has a bracket only, but the postage to the UK is way to much.
              • StevenBryant
                • Nov 2012
                • 366
                Tony from http://www.modelmarinesupplies.com/, he does an ofset rudder using the Octura kit
                • martin
                  • 2881
                  Kintec have the upgraded 3/16" inline strut & rudder for $28 + their offset z bracket at $15 + shipping of course.
                  • NativePaul
                    Greased Weasel
                    • 2770
                    What is the reason for you wanting to hang the rudder off the strut? Is it a narrow hull for straight lines or a wide hull for cornering, I have a 36" sprintcat .40/.80 for oval racing and use a Chinese 160mm rudder mounted independently from the strut, frankly I wouldn't want one bracket taking both the prop load and the rudder load on a boat the size and weight it is, that corners the way it does. A narrow boat will likely be much lighter and won't be able to generate the corner loads a wide one does so it makes more sense to me.
                    I bought mine direct from China trying to save a few quid, but Prestwich Marine sell them in the UK for £30-£33 depending on the length of bracket that you want, Mine is HF117 the 100mm bracket to get it back with the prop but HF118 and HF119 are the same rudder on different length brackets.
                    • sampit
                      • Jul 2009
                      • 466
                      Thanks Paul
                      I think your right! I will convert it back to the inline rudder setup, after all it is a very narrow hull and not realy for fast cornering
                      I just need to find some new wire for the 2mm ram quick links. looking like one end is glued and the other end soldered
                      Is the wire I need. brass plated wire,the same wire thats used on picture frames?
