hows this setup look for a 50" apache
  • skidooguymxz550
    • Jun 2007
    • 248
    5s2p going to a mamba monster powering a kb 45xl, actually two of these setups since its twin powered and i have wo of these motors in the boat
    i was thinking 4 4500 5s packs in total rated at 135amp discharge, seeing as thats 800 dollars will these batterys work for my apllication?
    what would i need for the nihm setup if i decide to be cheap?
  • ReddyWatts
    • 1756
    If you are wanting to use 5S? I would suggest the KB45 9XL's on x445 at 90 amps and 1600 watts, just not sure where you can get counter rotating X445 props?
    ReddyWatts fleet photo
    • skidooguymxz550
      • Jun 2007
      • 248
      cause we already have 11xls, would going for 6s2p for each side be worth it? i use plastic props so counter rotating aint no issue
      • ReddyWatts
        • 1756
        aah, yes it would need 6s for the 11XL with X450 props and 85 amps, 1800 watts.
        • skidooguymxz550
          • Jun 2007
          • 248
          do i really need to parrallel then if its only gonna pull 85 amps? the elite packs claim to be good for 135amps continuous
          • ReddyWatts
            • 1756
            Just keep the amps under 80% of the lipo 4500 battery 30C rating. That is 108 max amps, so a single set will work for each motor.
            This is at a speed somewhere between 35 and 45 mph.
            • skidooguymxz550
              • Jun 2007
              • 248
              thanks for the help, ill order the batts tommorow. now i just need to wait on them mamba monsters to be in stock somewhere
              • ReddyWatts
                • 1756
                Cant help you with those controllers. Never used any.
