I just scored a sweet vintage boat from a good friend. This is an 80's built, glass' over wood recreation of the 1964' Miss Notre Damn shovelnose unlimited hydro.
She originally came gas powered with a .40 motor, turning a 1/4'' flex shaft in a 5/16 stuffing tube, spinnung a bigass Octura X680 berillium prop.
An electric conversion is as simple as epoxying in a motor mount, connecting the coupler, adding floatation & connecting the power. But since I need to finish the mold for the front of the cowl, & lay glass over it to make the new front cowl hatch piece, I had a second idea.
What if I pulled the rear cowl piece off, and made one long flat hatch plate to seal the hull up, then use a high thrust ducted fan motor or two for propoulsion. I could even pull the strut, stuffing tube & the prop to reduce drag. That way when its up on plane, only the sponson bottoms & the rudder are touching the water.
The hull is 36 1/2'' at the edge of the shovel, with an 18'' beam. The hull itself is 2.5'' thick at its thickest point, and the sponsons the boat planes on are 3'' wide with an 1 1/2'' rise onto plane. I thought about it before, & I know its been done. There were a handfull of ducted fan hydros online.
I was wondering if anyone has seen it done, and/or what your thoughts are ?. Thanks
