6/32
Octura Collet 5mm x .078
What I do is buy quality Stainless steel set screw replacements local that have much better fit to wrench's in my toolbox. Never have a problem. I hate those black steel set screws, they always give out eventually.
Finally after visiting 8 stores and trying numerous allen key sets i found a set made in England that had a 1/16 that fit perfectly what a difference quality makes all the made in china sets I found were too small.
I think stainless is a good way to go a lot stronger tan the black. Thanks for all the input
Glad to hear you got sorted, quality nearly always pays. I believe some of the cheap Allen keys use the same key for 1.5mm & 1/16" I have a few sets where the 1/16" key is actually 1.5mm or .059" where as it should be .0625. 3 thou less dosnt sound much but on these small sizes it makes all the difference between undoing the screw & not slipping & rounding out the hex in the screw.
My 5mm x 150 Collet uses a .050...? maybe it depends on if they were made on FridaysOriginally posted by martin View PostGlad to hear you got sorted, quality nearly always pays. I believe some of the cheap Allen keys use the same key for 1.5mm & 1/16" I have a few sets where the 1/16" key is actually 1.5mm or .059" where as it should be .0625. 3 thou less dosnt sound much but on these small sizes it makes all the difference between undoing the screw & not slipping & rounding out the hex in the screw.
RC Grandpa
NAMBA Dist. 9
Folsom R/C Modeleers
That's what I thought, I use Team Associated quality racing hex driver, it fits quite well. That having said, some set screws do have variance in their specs as I also feel some fit looser than others.Originally posted by Jeff Wohlt View PostIt is a 1/16" hex bitToo many boats, not enough time...
FWIW I just threw one of these in to a HK order I just made - I'll report if it fits when it arrives
http://www.hobbyking.com/hobbyking/s...rewdriver.html2008 NAMBA P-Mono & P-Offshore Nat'l 2-Lap Record Holder; '15 P-Cat, P-Ltd Cat 2-Lap
, 1/16 too big.....
