bk bandit s cat
  • hammertime
    • 517
    bk bandit s cat
    well shes almost done..... just have to hook up the driveshaft to the motor and were set...... ill be runnin her tonight or tom either way pics and video will be posted!!
    60% of the time... it works every time!
  • SJFE
    • 4867
    Or Tom...what are ya sayin if you cant run tonight your givin her to me for testing?????:D
    • lferguson
      • 227
      Can you get some video?
      • Doug Smock
        • 5359
        Good luck!!!!
        MODEL BOAT RACER
        IMPBA President
        IMPBA 19887L CD
        NAMBA 1169
        • hammertime
          • 517
          thanx..... im going to try and get video.... my camera isnt working my buddy is supposed to go with me
          • hammertime
            • 517
            well i ran it today......... no video yet sry i will have some by sunday........ first run was good but i noticed that i had the srut too deep top speed est about 30 with the super vee motor and esc..... went home did a few more mods to the drive and repeaked the batts.... major difference and its all dialed in..... runs flat and strait no porosing at all... 12 cell about 35 or so..... not too much different from the sv..... when i take video of it i will have the other motor and esc in it.... should be a lot faster.... also gonna run 16 cells..... all in all i would say my first build was a success.
            • Doug Smock
              • 5359
              Way to go man!!
              First build huh? Congratulations Hammertime!!!!:)
              Doug
              MODEL BOAT RACER
              IMPBA President
              IMPBA 19887L CD
              NAMBA 1169
              • SJFE
                • 4867
                Nice job man!!!!..Now make with the video:D
                • lferguson
                  • 227
                  Awesome man.... I am impressed... My first one took a lot longer than that.:p
                  • SJFE
                    • 4867
                    Uhhh my first one still isent done...cause I wont leave it alone!!!...lol
                    • hammertime
                      • 517
                      yea lol..... just a question how deep should the srut be set on catamarans i think it might be too deep still
                        Strut depth depends on the hull, motor, speed, prop. The baseline is usually found by:
                        * Setting the boat flat on a table
                        * Adjusting the strut to be flat and level on the tabletop.
                        * Rudder perpendicular to tabletop.
                        This should get you close, but you may find that a bit up or down will perform a bit better. CG placement also effects the strut setting, usually between 30-35% ahead of the transoms, not the extreme back of the boat.
                        • hammertime
                          • 517
                          ok yea right now i have it set where the middle of the shaft is even with the transoms i guess im pretty much on runs flat and stable
                          • hammertime
                            • 517
                            sat ill be runnin her on video hopfully ill have the other motor and esc in i think it will be faster.... first i have to figure out how to keep water out!! i think its commin in through the strut and up the stuffing tube
                            • lferguson
                              • 227
                              Grease! I learned this simple trick last month. I think everyone but me knew about it. I use the same grease that I use for my flex cable. Works great, really great. went from about a table spoon or two in the hull after every run to virtually a drop or two.
