Wondered if I should go with a bigger Grim Racer prop or something like the x642? I am running a single 4s and upgraded the connetors. Any other ideas? Thanks.
Best Prop for Revolt 30?
I've ran x642, x445 & OSE 45mm CNC Props. the 42 I liked until I tried the bigger ones, and temps came in ok. the 45's can make the boat want to jump out of the water when fully accelerated from zero, the prop walk is also a little stronger, you must compensate with the S.Trim adjustment at the top end. My temps were ok as well with the 1800kv & 2030kv, but I have individual water cooling on my revolt.
Strut adjustment will take play on how wet or loose your revolt will ride. Friends have tried x 440/3 & (with larger speed controllers) x447/3, OSE 48mm CNC PropQ: Do you know the difference between Men and Boys...?
A: The price of their toys.
