I have sk180esc and turnagy 4084 1500kv in my genesis I have been running it with 2x 3 cell 5000 mah 35c venom. Timing on esc is 11.xx. I am getting about 40-45 mph speed and it seems like the motor is only running about half of its potential. It's just not screaming like it should. I have tried to recal the throttle a couple times with same results. Does the motor just want more amps possibly? I am nervous to try 8 cell on the sk. I am thinking just ordering a leopard is my cheapest solution to get it moving a little faster. Any advice would be great.
6cell or 8 cell with my set up
This topic is closed.
I would stick with 6s on that KV
what prop are you running?
and welcome to OSE !
yeah didn't think of that one.NAMBA20...Caterpillar UL-1, P-Spec OM29, P-Mono DF33, P-Spec JAE, Aussie 33" Hydro-LSH, Sprintcat CC2028 on 8s, PT SS45 Q Hydro, PS295 UL-1 power, OSE Brothers Outlaw QMono 4-sale, Rio 51z CC2028 on 8s
The SK 180 is a 6s esc (that's why the specs say 6s), I know a few have pushed to 7s. That also is not an 8s motor @ over 44000rpm unloaded, you need to look at problems with your boat set up as you should be seeing a lot more than 40-45mph.
I have a x442 it takes off with that. And also a grim racer l45x68 takes a second to plain but then takes off and I get a better top end. Honestly I think it is the motor the 3 wires coming off are real thin and I think they are restricting the current flow. All other wires are 10awg it is riding perfect in the water nice and flat. Anyone have experience with the aqua star 4084? I will post some pics if someone will explain how
As I stated in post above I have two props a 42 and a 45. Anything larger than the 45 would take to long to plain out. And I doubt I would get 10+mph out of a little larger prop. Also if the prop was way too small motor would just be over reving and that's my problem I feel like its not maxing out at wot. If I were to take a guess I would say its spinning at about 3/4 rpm And every connection has a 5.5 bullet. Just got nano tech 5000 mah 65-130 c. They seem to give me like 2-3 mph possibly. And just to leave the bs out of it I work on tractors cars trucks real boats you name it. It's just the electricity part that has me thrown off
A larger prop will plane faster. It has to be the correct prop though. And yes, you can easily gain 10 mph with a prop change. Think of it this way.. you have all that motor, right? Now consider that an Aquacraft ul-1 motor can easily turn that prop. That motor isn't even breaking a sweat, therefore, it's not really making any power.
A larger prop will not plane faster if you do not have the power torque. A motor will run hot if its either not enough strain or too much. Now I am not sure of the pitch on the grim racer. A electric boat should not take very long to plane out. I have the strut up as high as it will go and flat on the table
Well what prop do you suggest we will start process of elimination. Don't get me wrong it's fast but I feel like it should be running faster
Are you guessing the speed and rpm? About xx speed is not the same as measuring it to be fair. Also with that setup you could run a like x447/3 without heating issues. A small prop won't sound like it's revving, try a bigger prop.NZMPBA 2013, 2016 Open Electric Champion. NZMPBA 2016 P Offshore Champion.
I GPS the speed 39.7 mph on the x442 did not GPS other prop. But if it is taking long to plane on a 2 blade 45 why would I run a 3 blade 47? It would just take even longer to plane. Is it normal to take 2-3 seconds to plane out? Do the larger motors just take a minute to get rpms up compared to a smaller higher kv motor? I just don't want to be wasting money on props that are too big or too small.
It basically dose not have the snap off the line with bigger prop that I had expected. I believe the motor will have no issue turning the larger props but at the expense of the low end. The grim racer prop is a lifter prop by the way.
I think I might have figured out the problem according to the HK site I can not find a 4084 with a 1500kv the one listed is a 1050KV that would make a WHOLE LOTTA difference. Instead of turning 33,000rpm like you think you are, you are actually only turning 23,000!!!!!We call ourselves the "Q"
