building cyberstorm 33?
  • driftah
    • 759
    setting this hull up with a neu 1521 1.5d, sk 180 esc,x447/3 prop on 4s2p.....wondered from the pics I have seen which is better and why, By that I meant putting the motor closer to the transom and the batts forward being able to play with cog or having motor way up front with batts near back at transom.....advantages disadvantages etc??????? Im leaning toward the batts up front due to the obvious cog tunability but curious lol. Any help?
  • driftah
    • 759
    all the cyberstorms out there and no input...... what gives lol.
    • madmikepags
      • Aug 2012
      • 1371
      mine is in the center batteries on the side of motor much more tunability as far as COG I can move mine 5" forward or back, what I found more important is making a wet well and using a strut instead of a stinger, the ability to move the strut up and down without changing the angle is a big plus.
      We call ourselves the "Q"
      • madmikepags
        • Aug 2012
        • 1371
        BTW I won the 2012 nats 2012 Northern lights open, 2012 MMEU shootout 2013 Mi Cup and 2nd in 2013 Nats with this boat.
        • driftah
          • 759
          oops too late already used a speedmaster stinger lol, My only dilemma is that I already have a zicha cnc mount for my 1521 and wanna use it so it looks like I may be doing birch rails and lipos in the dead center of boat like propperchopper tony did, I did manage to get the boat to perfectly balance at 30 cog loaded but am concerned that I wont be able to air it out enough by moving batts back far enough like in my df29.That is when the water isn't rough hahaha
          • madmikepags
            • Aug 2012
            • 1371
            at the right speed for p mono you will need the cog more forward, for P-Offshore I'm at 35% and P-mono 40%, with the 1521 speeds of 70+ mph are easily attainable, I prop mine to do a little over 60 but rarely use full throttle in race conditions.
            • Tm27
              • Jun 2013
              • 40
              Sure would like to see some pics of this boat
              • kevinpratt823
                • Aug 2012
                • 1462
                What power/prop setup are you running here?
                My private off road rc track
                • driftah
                  • 759
                  power is a neu 1521 1.5d... prop will be an x447/3 then maybe an x450 if things go well..pics on the way
                    Hi,
                    I am using the x447/3 on my Pursuit with a leopard 4074 1800kv on 4s1p and 5s1p,
                    Top speed is 48mph on 5s1p and runs pretty stable.
                    But I am kicking around moving the setup for the cells,
                    My cg is at 9.5 with out the cell in place.
                    • driftah
                      • 759
                      Im still waiting for my carbon fiber inlay to arrive and I still have to cut my rails and construct the battery tray,cant do much more until inlay arrives zzzzzzzzz.
                        What size are those trim tabs ?
                        They look longer than mine at 1"7/8L x 1"W,
                        But I have two on each side on the hull.
                        • driftah
                          • 759
                          • driftah
                            • 759
                            the tape on the stinger is the cutoff point for better handling fyi, and I used associated blue thumbscrews on the rear hatch with stainless studs underneath and rubber grommets on top of hatch so no scratches. Hardware is 100 percent speedmaster and fins are ose large size.
                            • driftah
                              • 759
                              lenny I have those same tabs but wanted to try the ones pictured first to see what happens,less weight if they work for me size is unknown I gotta measure
