Water line choice
  • atechbh
    • 396
    Water line choice
    What is the best size and kind of water
    Tubing to use?
  • Basstronics
    • 2384
    Depends on your fitting size.
    • martin
      • 2881
      Size depends on size of boat & equipment ie smaller boats 3mm bore larger boats 4mm bore, tube is silicon.
        I would add that it also depends on the size of your pick up, it is pointless to have a big hose with a tiny fitting on the top of a rudder. Not all pick up is of the same size on rudders. Some VERY experienced members fit a larger than stock nipples on their rudders to have better volume flow. Also it is not advisable to run different sized tubing on the same set up.
