motor shaft / collet-coupler off center
  • jetnfast
    • Apr 2013
    • 162
    Hi guys,
    I am trying to finish up a boat and something is not right with the collet. Specifically, the collet assembly seems to be off center when I rotate it by hand in front of the stuff tube assembly. The off center wobble is very little, but enough to make me concerned about snapping a flex and excess vibration. I am running an outrunner motor...
  • Basstronics
    • 2384
    Anytime you have a slip fit on a set screw collar you will have run out. Also, the further away from the point where the difference is the more out of round it will run.
    I would try a higher quality coupler.
    • jetnfast
      • Apr 2013
      • 162
      Thanks for the advice. I would like to run an aeromarine but I don't think I can fit it in the current space between the stuff tube and the motor. I might need to search around for an alternative or two...any ideas?
      • Basstronics
        • 2384
        Octura makes a short version.
        http://www.offshoreelectrics.com/pro...Motor+Couplers
        • jetnfast
          • Apr 2013
          • 162
          Bass, thanks for the link, I am unsure about octura though, I prefer an aeromarine since I already run that on my Spartan with excellent results. I might order both and see which one works better (more true). I understand the octura uses a different type of tightening, which actually requires force compared the aero which is more lightly cinched since it has the brass olive nut...
          • Basstronics
            • 2384
            many people dont care for the 3 part as the brass tends to STICK on the flex making service difficult. Ive also lost a shaft/prop by not having it tight enough... $75 down the drain...
            Wont use them again.
