8mm or 5.5 bullets
  • atechbh
    • 396
    8mm or 5.5 bullets
    In the process of putting 2 boats together using 6S. Should I be using 8mm bullets for batteries and motor connections or just the batteries.
    Or 5.5 for all?
    5.5 should be good,
    But what setups and hulls are you going to use ?
    • Basstronics
      • 2384
      My "standard" among my boats is 5.5's (the good ones) on the motors and 8mm's on the batts. My rescue boat & my JAE 21 have 5.5's on batts.
      I do this so the same batts can go to any boat. Also if I want to swap motors around it makes things easier.
      • T.S.Davis
        • 6266
        My 6s boats are 8mm
        Noisy person
          Ditto with Terry.
          • T.S.Davis
            • 6266
            8mm is probably overkill but after you've already spent all that time and money building a beast what's an extra $10 on connectors. It's like building a custom car and saving on the cheapest wax you can find.
            Noisy person
            • driftah
              • 759
              I use 8mm everywhere and always unless it is a low amp draw setup like a supervee or 60 ish amp setup in general, Smaller connectors can cause resistance and therefore heat buildup so I don't take any chance of connectors becoming unsoldered while in use .Its more about choosing the proper connector for each setup like a 200amp setup will likely fail using 5mm bullets. Hence why massive car stereos use 1ga. wire and high end connections, Ya don't want ur car melting hahahaha
              • atechbh
                • 396
                K. Will go with 8 on batts and 5.5 on motors.
                Boats are a 36 deltaforce and a 36 team beleviever. 180 turnigy and leopard 4080 1600 kv. And have a castle 200 amp for the team believer but not sure what motor to use yet. What would I need on 6s and what prop to push it over 60mph reliably.
                • jcald2000
                  • 786
                  I use 8mm on everything even my UL1 motors, motors just convert the energy the battery's are capable of producing to rotational power, I don't want any restrictions in that path.
                  • atechbh
                    • 396
                    Where can I get reasonably priced decent 8mm bullets I need about 25 sets
                    • Livewire121
                      Fast Electric Adict!!
                      • 320
                      I use 8mm on my batteries and 6mm on motors.
                      HPR 115 - Lenher 2240/7, AS26- 150BL EVO ll esc's 92.3mph
                      • driftah
                        • 759
                        Ose sells em bud,8mm bullets
                        • atechbh
                          • 396
                          Perfect I will get them here.
                          • PvtSpoon
                            • Aug 2011
                            • 83
                            i use 5.5 on my setups but silver solder them just to be safe
                            • Ken Haines
                              Racer
                              • Jul 2007
                              • 673
                              These replies make no sense to me.
                              I have never overheated to the melting point any battery connectors.
                              Yes, on N2 set-ups they get pretty warm, but that is all.
                              On more than several of my boats I have over-heated to the point of
                              melting the solder out of the motor connectors.
                              So here is my set-up.
                              5.5's on all of my batteries
                              8mm on the motor leads if that particular
                              boat is a high amp set-up.
                              This way your battery connections are good for all of your boats.
                              In the case of the 8mm...... typically the high amp esc's and
                              the high amp motors will always be paired together so there
                              will be little non-compatability between your set-up connections.
                              I have also found the Polymax 5.5's with the step at about 2/3rds
                              of the way down the connector to be tighter fitting and far superior
                              to any of the other 5.5's on the market. They are hard to find but the
                              following ebay link shows the good 5.5's currently for sale.
                              They are well worth the extra trouble getting them as they definetely
                              stay cooler and maintain a tighter fit than other brand 5.5's available.
                              Make sure to identify that step about 60% down the male connector.
                              http://www.ebay.com/itm/Special-RC-5...5#ht_757wt_687
                              Hope this helps,
                              Ken
                              TenShock Brushless / Pro Marine
                              INSANE Boats / Rico Racing/ Castle Creations
                              2023, 2024 NAMBA & 2018 IMPBA FE High Points "National Champion"
