just bought the sport bec from ose. running (2) 3-s packs in series and hobbywing 180 esc with cap board. where is the most convenient connection point for the bec?
bec
Well first if you use an external bec then you will have to pull the red wire out of your esc (to rx) plug to dissable the internal bec in the T180.
The easiest place to connect a bec is on the + and - wires where your esc power plugs connect to your batteries.When you know it all.......you never will learn anything new
Either place would be fine....just wire it so when you disconnect your battery from your esc that it also disconnects the bec so you don't forget to unplug all powerWhen you know it all.......you never will learn anything new
The only problems with using the"balance" leads is .........most are only rated for 5 amp.
If you are plugged into the - of the first cell and the + on the last cell ...the cells drain equally
If you have a 4s pack and you are using the bec on only 2 cells out of the 4s then you will have a greater drain on 2 of the 4 cells.When you know it all.......you never will learn anything new
it's true you have to connect to the outer wires of the balancer leads so you use all the cells , forgot to mention that)
5 amps (think it will be less),say a 4s pack: that gives 74watt's to use
na way that little servo motor with a huge gear ratio is going to pull 74 watt ( say 6 volts ;that would make it to pull 12 amps !)
those motors pull around a couple 100mahLast edited by iop65; 06-28-2013, 03:16 AM.
Remember that if you use any of the balance wires (usually 22 or 24 gauge) the - and + are rated at 5 amps each
(batt voltage and mah doesn't change this)......... the total acceptable load on either wire is still only 5 amps ......not 10 amps combined.
the CC bec that I have is rated at 10 ampsWhen you know it all.......you never will learn anything new
i know that truckerdan
but voltage changes the max watt's you can pull through those wires ; when you use 1cel : 3.7v X 5Amp gives 18.5watt
when connected to a 5s lipo you can pull 3.7v x 5 amp :92.5 watts through the same wire ( in theory)
that's the reason why they up the voltage of the net in some country's : more power through the unchanged net
but i doubt if you can pull 5amps through the litte wires of my external bec ,but as i said a servo motor pulls something around a couple 100mah
Here is how Castle creations says to hook up a seprate BEC
cc_bec_wiring_diagram.jpgWhen you know it all.......you never will learn anything new
