are they new batteries? is the boat running wet? With the same exact setup I can pull a 648 with cup on good 4s 5000's 1P and get the batts around 140, with 6600 mah you should run cooler especially with a 445 theres something not perfect there. Hyperion 35C are as good as most other companies 50-60C rated batteries unless they are old? also I don't like cells smaller than 4000's in boats, I just feel the smaller cells heat up no matter what, I feel the lager cell dissipates heat better, I have no proof just my feeling. 85% of my boat batteries are 5000's and up the rest are 4000-4500
What Prop To Run Delta Force 33
according to what you say you will be running 8S? is that correct? what is the # on the motor 8-9-10??? you're talking close to 40K rpm and a 2pole motor compared to NEU's that are 4 pole. that motor is much more suited to 6 cell, on 6 cell i would use a 445-447 maybe try a 440 on 8cell?We call ourselves the "Q"
Hi madmikepags,
Yes i running 8s , lehner is 2250/9.
I can try these propellers x440 / 3 prop, m445/2, x450/3 and x452/3 ?
Few picture my deltaforce 33 :D
Is the boat painting fine do you think?Deltaforce 33" cyberstorm 8s Lehner 2250/9 1315 kv/ Leopard 4082 1250 kv .
skip those props and get a cnc from ose. They make the octuras and such look silly. I ran x445 for a bit with mm modded, medusa research 36/70 2300 3s to 6s (holy amp draw). http://www.offshoreelectrics.com/pro...od=cnc-4214250
way nice.
I will try to weigh it for you tomorrow. With Aquacraft motor +120amp esc or 4092-2200kv fightercat+ SF200 esc?
Hi Ray,
My boat weighs 4600 grams in running water .
Is it too much ?
Setup: hifei swordfish 300 a pro plus esc , lehner 2250/9 1315 kv motor + x2 4s 6600 mah 70 C lipo batteries in series.
Props: x446/3,x450/3 or x452/3 ? Are those too big or not?Deltaforce 33" cyberstorm 8s Lehner 2250/9 1315 kv/ Leopard 4082 1250 kv .
jasburrito, the cnc props are nice but an experienced racer really has no use for them, there really is no tuning them to specific boats and conditions, I have well ove 200 props and I can say there is not one of them thats stock.We call ourselves the "Q"
The fins came from OSE Ray....
Originally posted by ray schrauwen View PostAre those the carbon Chinese turn fins?? I have a set and want to use them on my DF33.....Bob Zola NAMBA 212
2022 NAMBA Nationals FE High Points Champion
Owner www.mojoracingproducts.comTeam Driver: Black Pearl Hydroplanes
I run a ICE240 CastleBob Zola NAMBA 212
