I have a Blackjack 29 with all stock electronics and stock prop,running 2-2s packs they get really hot. What would cause this ? thank you
Batteries getting HOT
That is quite low, long run time will be hard on the packs. That is 3.1 v per cell, lvc territory, 3.3v lvc is usually considered minimum, I think you should time you run to 2 min. And check you temp and batt. Voltage.
Sent from my Droid using Tapatalk 2Too many boats, not enough time...
Yeah I figured that was to low I figured the LVD on the ESC would've shut the boat down when it hit LV . what is the point of having LVD on the ESC if it doesn't shut it down. All my car esc's shut the car down when it hits LVMichigan Fast Electric SAW Club
4 to 5 minutes.
You should also get the prop sharped and balanced and that will help to,
It will let the setup not work so hard.
Get some video's of it running,
If it is running to wet that will also add more heat to the setup.
I think that may be a Pro boat problem,
This is a new esc and motor and could have some issues from the factory.
