Prop advise
  • Gabe_k
    • Jan 2012
    • 126
    Prop advise
    Well, ive decided to bring my old beat up miss geico back to life.. Im planning on re fiberglassing the thing and fixing all of the damage. Im ordering a new rudder, upgraded flex cable, new canopy, and a leopard 3674 3270kv (this will be a 4s boat so the kv should be okay right? or should I lower it down a bit) it will have either a seaking 180 or turnigy 180 esc.
    Giving the provided info, what type/size/pitch prop should i run? Obviously i want this boat to go fast, but id rather have reliability.
    • 5660
    3270kv x 14.8v=48,396rpm ( unloaded) =
    Try 2200kv with 4s.
    • Gabe_k
      • Jan 2012
      • 126
      Lol I do not understand motors at all! So with a 2200kv, what size prop would work well?
        • 5660
        On that boat the x642 or m445 should work.
        Take a look at the recommanded motor/rpm chart that is under each motor on the web here. 48,396 is in SAW territory, you need to be in 30,000 range, give a couple thousand more or less for sport running.
        Mine has 4082 Leopard and the kv is 2200. With x642 the boat was GPS'ed at 53.3mph, I know other people have run faster, but you need to select the right kv.
        • Gabe_k
          • Jan 2012
          • 126
          I use to run 6s on the stock electronics and never had a problem... i never gps'd it but im sure it was somewhere near 50. however i dont have my 3s batts anymore and im trying to get somewhere near the same speed on 4s.. should i maye get a larger motor then? since you run the 4082, would that be a better match or what do you guys think i should run?
            • 5660
            Leopard 4074 should do, I will go with the 1400kv personally, I like reliability and that gives you a comfortable 31,080 rpm .
            Some may suggest you to the 1650kv, but that is at 36,630 rpm.
            Also I prefer "Y" wind motor over "D" wind.
              • 7990
              Since the OP is running 4S the 2200 Kv motor is what he wants...
                • 5660
                You are right, I don't understand where I went wrong!
                Please ignore post #6, I read your post #5 but had totally misread about what you were saying! lol...
                • Gabe_k
                  • Jan 2012
                  • 126
                  lol 2200kv it is! yes this will be a 4s boat for rec use, and the occasional jump off waterfalls and stuff
                  • Speedracer128
                    • Apr 2013
                    • 288
                    Gabe,
                    Your going to bring her back to life so you can launch her again of the waterfall? After I reinforced my hull she's much more solid. I put the 4082 in mine and she flies. I put the 1800kv. On 4s she runs ok and is fast on 6s. This weekend I'm going to try 5s. I use a 642 and ran her a couple times on x646
                    • Gabe_k
                      • Jan 2012
                      • 126
                      Originally posted by Speedracer128 View Post
                      Gabe,
                      haha yup!, just placed my order today so ill update this thread as i progress with it. gonna start fixxing the hull tonigh
                      • Gabe_k
                        • Jan 2012
                        • 126
                        Got the old motor mount/wood set up out..
                        Will be putting a 4082 motor and mount in there.. Also epoxied the heck outta my split seem. Lol
                        I filled the entire hull with expandable foam so there is no what I can get in there to do glass work so this will have to do.
                        Mods can you please move this to the miss geico forum
                        • Heaving Earth
                          • 1877
                          4082 is gonna suck down 2s packs quick. Are you planning on running 4s packs parallel?
                          • Gabe_k
                            • Jan 2012
                            • 126
                            Nope... Just 2 cells. They are 5200mah, not really worried about runtime right now... The 3 boats I've been driving lately never go through a set due to something failing lol I kinda have a feeling this boat will break before it dains the packs haha
                            • Gabe_k
                              • Jan 2012
                              • 126
                              I also may buy some 3 cells batts so I can run 5s... Don't think that'll last long either since its a 2200kv
