Props for genesis with 1515 1y
  • ozzie-crawl
    • Sep 2008
    • 2943
    I am just getting back into boats after a couple year break and have orded a genises.
    I would have liked a 6s setup but alrady have a 1515 1y and some 4s packs to run a 2p setup.
    Any prop suggestions would be appreciated.
    Ozzie
  • photohoward1
    • 1781
    2200 rpm/v ? 442 or 445
      Hi and welcome,
      I am running a Daytona just about the same hull as yours with the same motor.
      The setup is two 4s packs in parallel with Neu 1515 1y 2200kv and a 180a seaking esc and x442 prop,
      With a offset rudder.
      This is how yours should be running with that setup in it,
      I gps it at 56mph with two 4s 40c 5800mah packs stuffed in it and using the x442 prop.
      • ozzie-crawl
        • Sep 2008
        • 2943
        Thanks guys just what i needed to know.
        Will be running near the same Lenny. 2200kv on 4s (8000mah total) with a t180.
        Looks like a x442 it is. I normaly detounge X series prop. Is this worth while on that setup do you know ?
          Not sure about the detounging of the X,
          But if you run the m445 you will gain some more speed but loose run time.
          And also it will run a little hotter to.
          I have not run my Daytona in about a year now,
          But may be I will get it wet this weekend to test it out again.
          • ozzie-crawl
            • Sep 2008
            • 2943
            Thanks i have a couple props i can try but will start with a 442 as it seems a safe starting point for some sport boating
            • SirBudman32
              • Aug 2011
              • 701
              I ran my Genesis with the CC 1515 1y, T-180 on 5s with a M445. No heat problems just lots of torque roll. I tried a 442 on it as well but for me just was not enough.
              Modified Jae21, Stock Jae21, Cheetah, Ul-1, Shock Wave 26 V2 (Rescue Boat).
              • Chilli
                • 3204
                Detounging the X series is almost always worth While.
                Mike Chirillo
                www.capitolrcmodelboats.com
