on a 8 lb. rigger with leopard 4082 2000kv on 6-s with seaking 180 esc what props would be good for oval racing and easy on the electrics ?
4082 on 6-s
This is a fast combo but take care to not overprop it.My c.f rigger(6 lb) with same set up has been working good with 1450 reduced to 45mm and cup 3,3.GillGO FAST AND TURN RIGHT !
www.grsboats.com.br
4082
gil, are there any stock props that i can run that will get me in the high 70's low 80's . thanks. your new sponsons seemed to create more drag in my opinion or too much lift with prop forcing front down. not critisizing just an observation . your other videos showed a better running boat. by the way, your craftsmanship on your builds are second to none.
ABCH5 or H7 are good ones stock props. Your observation is right .....not the new sponsons but the high lift props used on SAW that need fine strut adjustments.Thanks for your kind words.GillGO FAST AND TURN RIGHT !
www.grsboats.com.br
