Tunnel Hull Rookie Question ...
  • viper1
    • 219
    Building/converting my first tunnel hull;
    I know that rear edges of transom, sponsoons and/or steps should be as sharp as possible for best performance. But how about the corners running length-wise,e.g. the inside of sponsoons. Should they be sharp as well ?
    Thanks in advance
    Wisdom is knowing how little we know
  • marko500
    • 862
    Yes
    • viper1
      • 219
      Razor sharp?
      • Chilli
        • 3204
        I myself don't spend too much time on the sides. I do make sure they are smooth and even. I do put allot of time in making sure the transom is sharp and even more time ensuring the bottoms are flat.
        Mike Chirillo
        www.capitolrcmodelboats.com
        • HTVboats
          • Jun 2011
          • 936
          Assuming your talking about the point where the inner sidewall attaches to the belly or roof of the tunnel? On a wooded build it is probably left square where in a fiberglass hull you will generally see a small radius, mainly as it is easier for glass to conform to a rounded edge in the mold, leaving less possibility for an air pocket or void that breaks later. A radius is stronger where a square makes more of a shear point.
          Dynamically water gathered by the sidewall while turning accelerates vertically against the roof of the tunnel. Into a square corner it may give more lift than a beveled or radius corner. Would this be enough to make the boat roll over easier? probably not. At speed in a forward motion it only traps air. The important edges are on the bottom and transom or sponson rears.
          Mic
          Mic Halbrehder
          IMPBA 8656
          NAMBA 1414
          • Chilli
            • 3204
            I was hoping you were going to chime in Mic. Thanks!
            Mike Chirillo
            • viper1
              • 219
              Mic
              No I actually meant the bottom corners. For sport running, I don't think the top corners would make a huge difference unless I'm searching for that last 1/100 sec.
              Assuming these are normally not in direct contact with the water.
              But the bottom corners I am interested in, not for the speed difference but handling and the like. It is a fiberglass hull so there is a small radius as standard.
              I noticed that some wood builds have the bottom sheeting actually overlap the insides, which brought up my question.
              Thanks everyone for chiming in !
              • viper1
                • 219
                Update;
                I sharpened the edges , marked by the red lines in the O.P.... and WOW I honestly never expected it to make such a HUGE difference!!
                Thanks guys, cornering is more than twice as fast now, where she would formerly just 'roll over like a bitch in heat' I can do some turns with WOT!
                No spin-outs anymore either with the correct steering dialed in.
                Once I figured out how to get the ancient fire-wire working with the PC, I might even get my video of the camcorder and prove it
                • kendt
                  • Jul 2011
                  • 579
                  My rule of thumb is sharp edges and corners under water and rounded above. I find sharp edges ding and nick easier than rounded ones but under water you def want em sharp.
                  • viper1
                    • 219
                    Apparently the Firewire port on the camera side has died, so I ended up with only able to do analog capture but here goes:
                    Mostly 4s, near the end is one pass on 6s, just before the camcorder batt died.
                    • GLRE Raptor
                      • Jun 2013
                      • 22
                      Wow great boat!
                      Sent from my Galaxy Nexus
                      Great Lakes Raptor Excursions
                      www.RunRaptorRun.com
