Newbie help with HK OSE strut upgrade
  • 90sparty
    • May 2013
    • 1
    I have a HK Genesis that I am upgrading the drive to 3/16. I got the OSE 80975 strut upgrade along with a brass tube and Teflon liner to work with a new 3/16" cable. However, the new brass tube does not fit into the strut like the stock stainless tube did (due to larger OD of the new tube). Am I correct in assuming that the Teflon tube just fits into the strut (it does) and acts to center the brass tube? Any help would be greatly appreciated.
    Thanks!
    Don
  • martin
    • 2869
    The brass tube should be fitted in the strut but going up to the larger sizes to use the 3/16" flex you need to mod the hole in the front of the strut. The simplest way on the Genesis to upgrade to 3/16" is to change the strut out like you have & remove the teflon liner & run the flex straight in the original stainless stuffing tube to which a few on this forum have done.
