Rudder selection and why?
  • Heaving Earth
    • 1929
    On that note I'll stay outta this one. Have fun fellas
    • Darin Jordan
      • 9446
      Originally posted by Heaving Earth View Post
      So it's possible, but doesn't it make more sense to build a twin to do it?
      I don't really think it does... The twins I've seen are VERY fast, but they all suffer the same issues... You have to get both sides PERFECTLY MATCHED... which is tough to do. Props, etc... all have to be matched and in alignment. If one is off, it's a "drag"... literally... Much easier to tune a single.
      That said... twins ARE very cool! :)
      Darin E. Jordan - Renton, WA
      • Darin Jordan
        • 9446
        Don't let people run you off... Everyone has their own unique online personna... I suspect even Rumdog would be worth having a beer with when he's not online... :)
        • Rumdog
          • 6667
          Lol :)
          • Doug Smock
            • 5359
            As long as he doesn't pull up to the pub on his Pocket Rocket.
            MODEL BOAT RACER
            IMPBA President
            IMPBA 19887L CD
            NAMBA 1169
            • Darin Jordan
              • 9446
              Speaking of that... I have one of those pocket-bikes that needs a new body... I need to get on ordering one of those! :)
              • kevinpratt823
                • Aug 2012
                • 1462
                How about some input/opinions on how far back the leading edge of the rudder should be from the prop, on mono, cat, or hydro?
                My private off road rc track
                • properchopper
                  rcgoatbuild@snotmail.com
                  • 7708
                  Kevin,
                  As I understand it, and conventional wisdom indicates, the drive dog should be (reasonably) in line with the front of the rudder blade to minimize crossplay between the prop and rudder which could cause "steerage" and other gremlins. Of course the rudder is, out of necessity on inline rudders further back but the prop thrust cone hits the rudder symmetrically.
                  Funny you bring this up because just now I trimmed a Spd stinger to meet this criteria on a little mono "hotrod" project I'm building for myself
                  • Zackthrills
                    • Apr 2013
                    • 305
                    Properchopper please send out post pics of you hotrod mono project you are building. I would like to see. my other question is how do you determine the links that the rudder should be out from the back of the boat and also the actual length of the rudder? is that determined by the size of the boat?
                    • FastVee
                      • 659
                      Hi, I am just getting parts for my twin expresscraft thunderbolt build.
                      the rear edge of the rudder is flush with the dog side of the prop.
                      Do you believe this will cause any issues? -dual struts and single center rudder will be used.
                      The hull is quite wide so maybe the props are far enough from rudder to cause any issues?
                      I would like to keep this rudder since next size up would go 2" further back and will mess up the looks....
                      -Pate
                      www.youtube.com/rangerpate
